RTMT alerts for UCCX Databse out of Sync
Hi ,
I have a customer who is constantly getting rtmt alerts from UCCX that the Database Out of Sync .
Please see the alert below:
MatchedEvent : Jul 16 08:00:38 UCCX01 local7 1 : 230: UCCX01: Jul 16 2013 15:00:38.926 UTC : %UC_LIB_DATABASE-1-DB_NOT_IN_SYNC: %[AppID=Cisco Unified CCX Cluster View Daemon][ClusterID=][NodeID=UCCX01]: Database is not in sync on both nodes AppID : Cisco Syslog Agent ClusterID :
NodeID : UCCX01
Replication status shows as 2 -good but keep getting this alert.
admin:show uccx dbreplication servers
This operation may take a few minutes to complete. Please wait...
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_uccx01_uccx        1 Active   Local                0
g_uccx02_uccx        2 Active   Connected     711       Jul  6 13:39:30
Is there a way to fix this or synchronize the Database tables.
UCCX version is 8.5
Thanks in advance for your help
Hall of Fame Super Red
Hi Saima,
It sounds like this bug;
Database is not in sync on both nodes alert in RTMT
CSCtw80338
Symptom:
RTMT alert should be informational only.
At Thu Dec 08 04:00:31 EST 2011 on node 10.251.254.120, the following SyslogSeverityMatchFound events generated:
SeverityMatch : Alert
MatchedEvent : Dec  8 04:00:03 PHLCC002 local7 1 : 32:
PHLCC002.cozen.com: Dec 08 2011 09:00:03.191 UTC :
%UC_LIB_DATABASE-1-DB_NOT_IN_SYNC:  %[AppID=Cisco Unified CCX Cluster View  Daemon][ClusterID=][NodeID=XXXXX]: Database is not in sync on both nodes  AppID : Cisco Syslog Agent ClusterID :
NodeID : XXXXX
TimeStamp : Thu Dec 08 04:00:03 EST 2011
Conditions:
RTMT alert for UCCX 8.x
Workaround:
None
Details
Last Modified:
Jul 16,2013
Status:
Open
Severity:
6 Enhancement
Product:
Cisco Unified Contact Center Express
Support Cases:
42
Known Affected Releases:
(2)
8.5(1)
8.0(2)
Cheers!
Rob
Hi Rob,
Thank you for the quick response .
It says in the bug :
"RTMT alert should be informational only"
Does that mean this is just a cosmetic alert and does not affect anything ?
Is there any version available with the fix?
Thnx
Saima
Hi Saima,
You are most welcome my friend!
I believe that this is what the bug is trying to say but it is very poorly
written
If it were me I would open a TAC case just to be sure as there are
no "Fixed in" versions.
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Sure I'll do that .
Thanks for your help
898
