RTMT compatible with windows 7
For some reason RTMT does not work on my windows 7 desktop it only works on windows xp. We have call manager version 8 and that is where I downloaded it from.  Any suggestions.
Thanks.
1 REPLY
Blue
What error you are getting. Is it giving error while installation or when you actually run the plugin.
It is supported in win 7 should not have any issues.
What version of Java you have??
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
411
