RTMT: Completly wrong time in logs
when we want to get logs fropm the cucm from our customer, we always get the wrong files. When i want to download log files from 2-4am i always get the wrong log files.
NTP is correct. Does anybody had this problem before? The customer use CUCM 8.0
Thank you.
Best Regards
Daniel
Hall of Fame Super Silver
Are you saying the info within the logs does not span what you want to see?  Logs may include more time as the entire log is collected which might not have been filled out completely.
Are you using local time or server time when pulling the logs?
Chris
VIP Super Bronze
You  need to check two things..
1. time on your cucm servers and
2. The time on the PC client you are using to download logs from.
Usually you get a warning when the time between the client and the server is un scynchronized
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Purple
Hi Daniel,
try to compare the timing between PC and call manager .
On CUCM , run utils ntp status from Publisher .
regds,
aman
Silver
The other possible issue is that the log range you wanted has mostly been overwritten already.
207
