RTMT Counter for Calls Between Locations
Mark H
Hi everyone,
Is the CallsInProgress under Cisco Locations counter the best counter to use to track the quantity of calls between locations?
For example, I have locations A, B and C. I want to know how many calls there are at any one time between sites A and B or C. However, I do not want to include calls that are within site A.
Mark
Chris Deren
Yes, it will shows you calls in progress to/from a particular location, but it will not tell you to or from which location it is.
HTH,
Chris
Chris Deren
HTH,
Chris
Sure does, thanks.
