Community Member
RTMT Error
While trying to verify SAF learned routes and SAF forwarder information from RTMT I recieve an error "An Error Occurred While Processing Request"
Does anyone help me to solve this issue?
1 ACCEPTED SOLUTION
Hi,Try to run the application
Try to run the application Run as administrator from the pc. Let us know if it works.
Manish
Manish
Community Member
Thanks for your support. It
Thanks for your support. It is working now. :)
That's good to know. Please
That's good to know. Please remember to rate all helpful posts and mark the discussions as solved if your query has been answered.
Manish
Community Member
Application is running. I
Its working now.
Community Member
Dear Manish,I am facing
Dear Manish,
I am facing another problem in Configuration. Can you please have a look
I have configured SAF in CUCMEs and configured a SAF Forwarder for CUCM. All CUCMEs are learning and advertising DNs and able to call each other. SAF Forwarder registered CUCM as client and in CUCM I can see learned DNs too. CUCMEs are learning CUCM DNs too SAF. I have created partition for learned DNs and CSS include that partition. But I am unable to call to these numbers. while digit analysis these learned DNs are not matched with any partitions and shows blocked due to unallocated number. Can someone help me to figure out what I missed in this configuration?
526
