RTMT message on low virtual memory
I recieved message in RTMT of the CUP 8.6
Available virtual memory below configured threshold . Configured low threshold is 25 %
jabberd (3021 MB) uses most of the memory.
Any suggestion?
I am no expert on Presence
I am no expert on Presence server, but I do know that when there is process consuming more memory than the Cisco Tomcat Service, it is related to a memory leak and caveats are filed to address these situations. I was able to find the following caveats while doing some research:
https://tools.cisco.com/bugsearch/bug/CSCuj65714
https://tools.cisco.com/bugsearch/bug/CSCtn77929
Hope this information helps,
Marco Rojas.
Marco,I will try update the
Marco,
I will try update the release of the server CUP. I think that can be the second bug - CSCtn77929, because the problem happens intermittently. I will investigate more time, if i discovered news I will send.
Thanks so much.
287
