RTMT - Monitoring 2 CM clusters on one PC simultaneously
Does anybody know if there is a way to run two instances of RTMT on one PC to monitor two CM4.1(3) clusters simultaneously??
Cheers!
1 ACCEPTED SOLUTION
Re: RTMT - Monitoring 2 CM clusters on one PC simultaneously
Copy the program directory (JRtmt) and start it from the new copy.
Green
Yes use VMware
Thanks ... you are a champion!
114
