RTMT not working after changing hostname on subscriber (unity connection)
latintrpt
Hello all,
Yesterday I moved my subscriber for Cisco Unity Connection to another data center.  I had it defined by hostname so I changed DNS to reflect the new IP.
Also changed the IP, name, and gateway under the OS administration.
The cluster was rebooted and replication is working just fine.
My only problem is that RTMT is reporting that the subscriber node "AMC service is down".  I have verified that the service is up on both the publisher and subscriber.  In RTMT the only node I'm seeing is the publisher.
Anyone have an idea as to what I'm doing wrong or missing?
I'm running version 7.1.3ES50.33039-50 on both nodes
15 Replies 15
ronpatel
Level 8
Level 8
Is there a possibility to do following procedure
This might be due to enterprise replication being broken between the publisher and subscriber.
on sub:
utils dbreplication stop
on pub:
utils dbreplication reset all
This should rebuild the enterprise replication (OS level informix replication).
Confirm RTMT state is 2 on both pub and sub with:
utils dbreplication runtimestate
utils dbreplication status
Then make sure the UC application replication is good with:
show cuc cluster status
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
I think I have a replication issue
Publisher:
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication status command started at: 2012-04-15-21-59
There no active nodes in the replication network
DB Version: ccm7_1_3_33039_1
Number of replicated tables: 427
Cluster Detailed View from PUB (2 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT) & details
rudua-unity001  10.74.13.229    0.042   Yes     Off-Line        N/A     match   Yes     (2) PUB Setup Completed
rupua-unity001  10.74.213.229   0.226   Yes     Off-Line        N/A             N/A     () Not Setup
admin:show cuc cluster status
Server Name     Member ID  Server State  Internal State  Reason
rudua-unity001  0          Primary       Pri Active      Normal
rupua-unity001  1          Secondary     Sec Active      Normal
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_ciscounity_rudua_unity001  100 Active   Local           0
g_ciscounity_rupua_unity001  101 Active   Connected       0 Apr 15 05:19:13
Subscriber:
Cisco Database Layer Monitor is not running
g_ciscounity_rudua_unity001  100 Active   Connected       0 Apr 15 05:19:13
g_ciscounity_rupua_unity001  101 Active   Local           0
Any idea on how to fix this and do I need to this on a down time?
Thank You
You can use the command for forceing the replication on to subscriber
utils dbreplication forcedatasyncsub
Reference:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cli_ref/7_1_2/cli_ref_712.html#wp69932
This command forces a subscriber server to have its data restored from data on the publisher server.
Use this command only after you have run the utils dbreplication repair command several times, but the utils dbreplication status command still shows non-dynamic tables that are not in sync
Note Do  not run this command if only dynamic tables are out of sync; dynamic  tables can be out of sync during normal system operation.
You can only run this command from the publisher server. Use the all parameter to force sync on all subscriber servers in the cluster. If only one subscriber server is out of sync, use the hostname parameter.
After you run this command, you must restart the restored subscriber servers.
This command can take a significant  amount of time to execute and can affect the system-wide IOWAIT.
Hope it helps.
Anand
Pls rate helpful posts !!
anchoudh
Level 9
Level 9
Did you reinstall the RTMT after you made changes on subscriber?
Please add the hostname entries in the RTMT client box and select the new ip address once again to login.
Hope it helps.
Anand
Whenever I start the Cisco Database Layer Monitor on the subscriber, it starts and then it stops.
Should I still do the above with forcing replication on the subscriber?
Could you please check the servicability page to verify if the services are running and stable?
Anand
All services are started except for: Cisco Database Layer Monitor, Cisco RIS Data Collector, and Cisco Log Partition Monitoring Tool.  I tried starting these services.  They do start up but then stop running.
This is only an issue on the subscriber.  Publisher services are all fine.
Please do above procedure which is mentioned in my previous post. It will help you.
regards
Ronak Patel
Rate helpful posts.
Ron, I have tried the above you listed, but i get the following:
Publisher:
Subscriber:
Any reason why the Cisco Database Layer Monitor keeps turning off on the subscriber?  I would think this would cause issues if I try to rebuild the database on the subscriber.
"utils cuc cluster overwritedb" in Sub will copies data from the publisher to the  subscriber.  See if this command helps, If not I would suggest you to raise the Cisco TAC case.
Ronak Patel
Latin,
Do you see any error while booting the Sub ? Anything mentioning about using recovery CD to fix any issue as such ?
Due to malfunction or file corruption, Services will have similar issues & using recovery disk while booting fixes it.
GP.
Date: Apr 15 05:20:02
Machine Name: rupua-unity001
Severity: Critical
Process:  Cisco Database Layer Monitor
Message: : SDIDBConfigData:Read failed. ProccessNodeIdException = Could not locate process node id
I saw this in RTMT
No, I meant, did you see any message on server console ( not RTMT ) asking to use " Recovery Disk " while booting the server ?
GP.
