RTMT on CCM 4.2 Java error
When I start the RTMT on the servere or on a client connection to the server i get a java.util.missingresourceexeption error.
can anyone help me with this problem how to get i solved ?
Best regards
Soren Knudsen
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: RTMT on CCM 4.2 Java error
Hi Soren,
You may be hitting this bug;
CSCse78153 Bug Details
RTMT does not work on winos 2000.4.3a or 4.3SR1
Symptom:
RTMT can not work after upgrading to winos 2000.4.3a sr 4.3SR1 with following
error.
java.util.MissingResourceException: Can't find bundle for base
name org.apache.xerces.msg.XMLMessages, locale ja_JP
Conditions:
OS upgraded to 2000.4.3, 2000.4.3a, or 2000.4.3aSR1. This documents the need
for RTMT to function correctly when RemoveServerHeader=1 in urlscan.ini.
Workaround:
Change the value of RemoveServerHeader in urlscan.ini
(C:\Winnt\system32\inetsrv\URLscan\urlscan.ini) from 1 to 0 and reboot the server.
OS 2000.4.3asr2 sets RemoveServerHeader to 1 to workaround this issue until
RTMT can correct behavior.
After upgrade to 4.2(3) 3.3(5)ES49 4.0(2a)ES88 4.1(3)ES72 4.2(1)ES21
RemoveServerHeader can be set back to 1.
1st Found-In
4.1(3)
4.1(3)SR3
4.2(1)
Fixed-In
4.2(2.116)
4.2(3.1)
3.3(5)ES49
4.0(2a)ES88
4.1(3)ES72
4.2(1)ES21
Hope this helps!
Rob
Hi Soren,
Symptom:
error.
Conditions:
Workaround:
1st Found-In
4.1(3)
4.1(3)SR3
4.2(1)
Fixed-In
4.2(2.116)
4.2(3.1)
3.3(5)ES49
4.0(2a)ES88
4.1(3)ES72
4.2(1)ES21
Hope this helps!
Rob
Hi Rob,
Thanx it fixed it :-)
/Soren
Hi Soren,
You are most welcome! Always some strange errors aren't there?
Take care,
Rob
142
