RTMT on windows 7
hello Mates,
does anybody knows if Winodws 7 is a supported OS for RTMT for CUCM 6.1 ?
cheers
Alex
Re: RTMT on windows 7
No, the target release is Version 8.5, FCS Q4CY10
Cisco Unified Communications Support for Microsoft Windows 7
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_bulletin_c25-563280_ps7056_Products_Bulletin.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Where do I download this.
I have Windows 7 (64 bit), but the one I downloaded from a CUCM ver 7.1 plugin is not supported under Windows 7.
Any idea where to download this from?
Bijay
Refer to the document I posted which mentions when it will be supported and on which version.
You can only download RTMT from the plugins page from your CCMAdmin.
java
java
AFAIK 8.5 isn't released yet correct?  I think thats what javalenc was
saying.  Not yet, its planned though.
I have windows 7 64 bit and I downloaded RTMT from the server (7.1.3) and the version of RTMT is 8.1. It works fine for me, I just dont remember if when i installed it i used the compatibility wizard or not, might give that a shot.
It does works.
thanks Tracy.
FCS Q4CY10 has come and gone. Will RTMT 8.5 be available?
2886
