Community Member
RTMT sending false Alarms?
We have randomly receiving following alerts on RTMT
  1. MGCP DChannel is out-of-service
  2. Number of registered gateways decreased in consecutive polls.
  3. Number of registered gateways increased between consecutive polls.
We have,
CUCM: 9.1.2.11008-1
Voice Router: 15.1(2) T1
I log into the router and the controllers/ports show no errors on that PRI.
I checked isdn service, status and logs but still no sign of down.
Also we can see active calls on that PRI from RTMT.
Is RTMT sending false Alarms?
1 REPLY
RTMT is probably not sending
RTMT is probably not sending false alarms. What level do you have your logging set to?
HTH Regards, Yosh
168
