RTMT Trace
Hi all,
Can anyone advise me how I pull call logs from particular gateways in RTMT?
i.e. which menus to go through in trace and log central?
Re: RTMT Trace
if what you're looking for is ccm trace from only one device you would need to configure that before gathering the trace, that's under trace config. otherwise you will pull info from all devices as there is no filtering for that when gathering the trace
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: RTMT Trace
Ok so do I go:
realt time trace > ccm > call manager > ?
Sorry I do not know how to navigate the logs
Re: RTMT Trace
if you want to configure them it's in serviceability
if you want to gather then open RTMT
Trace -> Collect Files
java
java
Re: RTMT Trace
Ok so do I go:
Re: RTMT Trace
Alternatively can I view logs of calls coming in?
Re: RTMT Trace
traces do not have that kind of filtering, you can see all the activity from a single phone but i mean ALL activity (off-hook, on-hook, user pressed a softkey, etc)
you would need to look at the trace for incoming calls manually
java
java
Re: RTMT Trace
Thanks for the info, I'll look in to it
188
