RTMT Trace
Why I don't see trace item in the Realtime monitoring tool?
I have CCM 4.1
  • IP Telephony
1 REPLY
Re: RTMT Trace
if you mean that you want to collect the traces using RTMT that is for 5.x and 6.x, in 4.x you need to use the trace gathering tool or manually pull them from program files/cisco/trace
Set Up Cisco CallManager Traces for Cisco Technical Support
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
java
if this helps, please rate
www.cisco.com/go/pdi
111
