RTMT version
I got Unity Connection cluster 7.1 for which I want to run RTMT, I got rtmt from cucm 7.0 but it doesn't work, gives me an error saying not compatible with the backend system. where can I get a the rtmt to run it on my uc 7.1(5) ?
1 ACCEPTED SOLUTION
Re: RTMT version
In the left column menu under System Settings>Plugins then click the find button.
Re: RTMT version
Re: RTMT version
Thanks Ray, looked at those options a number of times, can't believe I missed it. Got you 5 points for pointing out.
cheers.
Re: RTMT version
No problem. Thanks for the points!
303
