Community Member
RTP G.722 capture
Guyz i need to know if its possible to capture  RTP streams using G.722 with wireshark and play it ??? and if not can i like change the IP phone settings to another type of codec , im trying to do all this to find out if my voice traffic is encrypted or not.
Hall of Fame Super Gold
RTP G.722 capture
You should ask this on a Wireshark forum.
VIP Super Bronze
RTP G.722 capture
You can disable G.722 at a per-device or system-wide level. On the device there is a Product Specific Configuration parameter called Advertise G.722. Set it to False and any call to/from that phone will be G.711 or lower only.
Please remember to rate helpful responses and identify helpful or correct answers.
317
