08-21-2014 04:41 AM - last edited on 03-25-2019 08:30 PM by ciscomoderator
Hello community, I have a question
The setup is this, a cisco sccp phone is located in russia and registrated in a callmanager located in denmark. The phone dials a number that translate and use a routelist to a local gateway in russia. The dialed number in the local cisco gateway is a dialpeer with a siptrunk to a lync mediation server also located in denmark.
How is the final rtp stream going to be from the cisco phone to the Lync server?
Br. Kasper
Solved! Go to Solution.
08-21-2014 05:29 AM
Assuming you're not invoking an MTP or TRP, from the phone to the SIP trunk.
Otherwise, phone -> MTP/TRP -> sip trunk
08-22-2014 06:13 AM
Thats correct , you need to move your resource to local so that the source ip will be different from the cluster.
Or you can use CUBE feature on local gateways and map different source IPs on inbound side and outbound side , so the all request from this gateway will add their IPs/ports in their sip messages to lynch server and act as media flow through.
08-21-2014 05:29 AM
08-21-2014 05:33 AM
I am not sure if RTP between a SCCP cisco phone and an Lync client will work.
Think you must proxy the rtp
Jan
08-21-2014 11:00 PM
Br. Kasper
08-22-2014 03:56 AM
As you are doing conferencing , so RTP path will depend upon where this resource it located , if conf resource is in Denmark then RTP path will be...
Phone (Russia) ---Conf Resource (Denmark Cluster) -- SIP trunk (Russia) -- Lync Server (Denmark)
If resource is located in Russia then flow will be..
Phone(Russia) - Conf Resource (Russia) - SIP trunk (Russia) - Lync Server (Denmark)
08-22-2014 04:26 AM
Hi. It actually all comes down to the reporting in Lync. The issue is that Lync reports "bad" conferance per Sip trunk. I want to make a more detailed design where I place a SIP trunk in every affilliate around europe in their local gateway, but as the phones are registrated in cucm cluster in denmark and the Lync mediation server(sip trunk connection to local gateway) also is located in denmark, I need a redesign of the rtp path including the MTP, that is why I want to put the MTP resource in the local affiliate gateway(this eksample russia) So by doing this the rtp path would be phone->local mtp->local vgw-siptrunk->Lync mediation in denmark. I just needed a secound thought on the design.
The current setup would report all "bad" conferances as beeing in denmark, even if they are originated in other countries. The local dialpattern is just callcorwarded to the dk siptrunk->Lync mediation.The SIP trunk in cucm are limmited to only one connection to the Lync mediation server.
08-22-2014 06:13 AM
