Run On All Active Unified CM Nodes
in new version of CUCM, in route list, there is a check box,
"Run On All Active Unified CM Nodes", based on Cisco documentation it syas: to run on every node, check this check box
Could someone explain it a bit, once we add a route list, it will be added to all Subscriber by default. what is the urpose of having it?
Hamed
1 REPLY
Hall of Fame Super Silver
Hamed,
I sugest you read on this in the SRND as it does have a very good and comprehensive  explanation of this feature.
HTH,
Chris
694
