Running CCX Editor v902 on Windows 8.1?
Am I wasting my time trying to get CCX Editor to run on Windows 8.1? I've tried running it in compatibility mode with no luck.
Hi,As per the UCCX 9.0(2)
As per the UCCX 9.0(2) software compatibility matrix, Windows 8 or 8.1 is not supported for Editor
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_9.0%282%29
Same is the case for UCCX 10.5
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.5%281%29
Manish
Looking forward to 2016 when
Looking forward to 2016 when Windows 8.1 is supported :)
Got the ccx editor 10.5 to
Got the ccx editor 10.5 to install on windows 8.1 by installing with compatibilty mode but it wont. i have tried hard....moving on to look for a windows 7 machine.
Im running on Windows 8.1.
Compatibility mode for Windows 7
Run this program as Administrator
Edit hosts file
[IP of UCCX Server] FQDN of UCCX Server
Didn't work overhere, CCX
Didn't work overhere, CCX Editor for UCCX 10.5. Installed fine with compatibility mode for Windows 7 but starting the application did not, UCCX server is in hosts file.
Uninstall is now stuck on Registry entries.
Set the application to run in
Set the application to run in compatibility mode for Windows 7 and Run as Administrator
As stated, this didn't work
As stated, this didn't work for me, the issue was due to two bugs:
https://tools.cisco.com/bugsearch/bug/CSCuu18876
https://tools.cisco.com/bugsearch/bug/CSCuq83669
Now it works fine (on IP address), DNS still needs to work though to enable repository browsing.
Odd. I did a clean install of
Odd. I did a clean install of Windows 10 recently and was able to install CCX Editor by making the host file modification and running the install in compatibility mode for Windows 7 and as Administrator. Once installed, it runs natively. We are running 10.6(1) which may be the key difference here
1168
