Running config after taking voip
After we took voip in use in our 3560 switches appears strange looking code in the beginning of running confing. It looks like "mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
Is that important and is it possible the hide those codes.
thanks
Juha
1 REPLY
Re: Running config after taking voip
it should be the auto-qos and it is important.I don't think you can hide it unless you remove auto-qos
100
