Running CUCM 8x/9x on Cisco UCS - Design
I have a design question popping in my mind regarding running CUCM 8.X/9X on UCS.
Let us say that I have initially configured a CUCM Publisher and Subscriber to run on a Cisco UCS server using the VMware OVA Template that allows for 2500 IP Phones.
Both CUCM servers have been installed and setup using the specs from an OVA that allows 2500 IP Phones. Later, I decide to increase the capacity of the same hosts from 2500 IP Phones to support 7500 IP Phones.
Do I need to build up new CUCM servers using an OVA Template that allows 7500 IP Phones per server or do I modify the existing CUCM VMware host settings such as increase the RAM, HDD, etc.
Warm regards,
JK.
1 ACCEPTED SOLUTION
If the change only involves changing the CPU or RAM, yes, you can go ahead and change it by shutting down the VM.
If it requires changing the HDD size, you need to install the new VM using the OVA you want, and DRS.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Hall of Fame Super Silver
Check out the resize support:
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements#Resize_Virtual_Machine
Since the 2500 OVA have different storage requirements from the 7500 OVA you will need to rebuild the VM for full support.
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Communications_Manager_(CUCM)#Version_9.1.28x.29
HTH,
Chris
149
