06-07-2014 12:41 AM - edited 03-16-2019 11:02 PM
I am using CUCM 9.1 and configured SAF between CUCM Cluster and CMEs. All CMEs are learning the patterns and inter calls are successfully made. CUCM side, SAF forwarder is learning the patterns also advertising. But I cannot see any learned pattern in RTMT. I am receiving an Error while checking both SAF learned Patterns and SAF Forwarders. Error Message is " An Error Occured While processing". What may be the reason and how can i resolve it?
I attach Screen shot of the Error Message.
Solved! Go to Solution.
05-05-2016 11:50 AM
05-05-2016 11:50 AM
