SAF Plug in Dial Peer not being matched
2 CUCM 9 clusters connected via 2951 routers and successfully using SAF/CCD between them.  One of the CUCMs also has a  second  2951 as a CME router also running SAF.
This particular client wants a "default / catch-all" dial peer that dumps calls to the CUCM (just assume that this is a non-negotiable point)
CUCM 2 is hosting DN pattern 16xx.  This pattern is visible to the CME router as evidenced by a show voice saf dndb all statement.
A call generated by an IP phone hanging off the CME to a 16XX number is matching to the catch-all dial peer and not to the SAF Plug-In dial peer, as evidenced by doing a  debug voice dialpeer and watching the outbound dial peer matches.
Partial configuration of the router is below:
dial-peer voice 3 voip
description Default Dial Peer for SAF
destination-pattern .T
session target saf
dial-peer voice 1028 voip
description Default Catch All Dial Peer to dump to Corps CUCM
translation-profile outgoing 10
destination-pattern ....
session target ipv4:172.16.57.60
dtmf-relay h245-alphanumeric
no vad
I ran a number of tests, altering the destination-pattern of the SAF dial peer and then watching the output of a debug voice dialpeer command.
Even if I changed the destination-pattern to a complete match, ie destination-patten 1600, dial-peer 3 does not match and the call matches to dial-peer 1028.
However, if I change the SAF plug in dial-peer to be a normal dial-peer, ie I replace the session target saf command with session target ipv4:1.1.1.1, and place the same call, dial-peer 3 then matches.
Below is the router's SAF configuration
router eigrp SAF_FORWARDER
service-family ipv4 autonomous-system 11
  topology base
  exit-sf-topology
  neighbor 172.16.88.1 Loopback0 remote 10
  neighbor 172.16.88.2 Loopback0 remote 10
  neighbor 172.16.88.6 Loopback0 remote 10
  neighbor 172.16.88.16 Loopback0 remote 10
  neighbor 172.16.88.18 Loopback0 remote 10
  neighbor 172.16.88.20 Loopback0 remote 10
  neighbor 172.16.88.52 Loopback0 remote 10
  neighbor 172.16.88.54 Loopback0 remote 10
  neighbor 172.16.88.56 Loopback0 remote 10
  neighbor 172.16.88.86 Loopback0 remote 10
  neighbor 172.16.88.88 Loopback0 remote 10
  neighbor 172.16.88.90 Loopback0 remote 10
  neighbor 172.16.88.124 Loopback0 remote 10
  neighbor 172.16.88.125 Loopback0 remote 10
  neighbor 172.16.88.126 Loopback0 remote 10
  neighbor 172.16.88.127 Loopback0 remote 10
  neighbor 172.16.88.128 Loopback0 remote 10
  neighbor 172.16.88.51 Loopback0 remote 10
exit-service-family
voice service saf
profile trunk-route 11
  session protocol sip interface Loopback0 transport udp port 5060
         profile dn-block 11
  pattern 1 type extension 6[01]XX
  pattern 2 type extension 999X
profile callcontrol 11
  dn-service name CCD
   description CCD over SAF
   trunk-route 11
   dn-block 11
call
channel 11 vrouter SAF_FORWARDER asystem 11
  subscribe callcontrol wildcarded
  publish callcontrol 11
So, anyone with any thoughts on why Im not matching to the SAF Plug-in Dial Peer?
Jeff
349
