SAF questions
Hello Guys,
I would like your help in order to give me some answers regarding my doubts about SAF.
I will configure a SIP trunk in order to use SAF for my calls to other country.
Is that all that i need to get it working? I mean? Should i build route patterns to their advertised numbers or the phone will know automaticatlly the patterns to use?
Thanks in advance.
  • IP Telephony
SAF questions
Have you already reviewed the related documentation???
Call Control Discovery
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fscallcontroldiscovery.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
SAF questions
Should i consider this document as a reference to deploy it? Everything that i should know is on it?
SAF questions
The phone will automatically be able to dial learned patterns assuming the partition for learned patterns is in the devices CSS.  No need to create additional route patterns.
301
