06-16-2010 07:06 AM - edited 03-15-2019 11:16 PM
We are looking at upgrading to CUE 8.x and are wondering about SAF support on the AIM2 or NME cards. We don't want to buy the AIM2 and find out that it won't support SAF if/when this becomes available.
Anyone have suggestions about which card we should be buying with respect to SAF support?
Joey
06-16-2010 09:13 AM
I'm a little confused why you're looking for SAF support in Unity Express. The Service Advertisement Framework would be a Communications Manager or Communications Manager Express feature.
The Q&A on SAF states this:
06-16-2010 11:09 AM
SAF is not supported on CUE today, but surely it might be, as the whole idea behind SAF is that it should be general.
It would be terrible to buy a bunch of AIM2-CUE cards, open up a pile of routers to insert them, deploy the product and then discover that in the next release SAF is used instead of VPIM but only on NME cards.
Joey
