03-01-2007 03:40 AM - edited 03-14-2019 08:16 PM
hi:
My case that i have multilocation and in each site i have a voice gateway and the users have permition to call an outgoing call such as mobile 07XXXXXXX, my point that how can configure this common pattern to be route for each location gateway
thanks for advice
03-01-2007 04:34 AM
You can do this using partition. Setup partitions for each of our sites. Assign device pool of each location to to a distinct partition you created. For example, at site A assign all the devices to partition A. Also assign the site gateway to partition A. Then create a route patter 07xxxxxxx and also assign it to partition A.
For another site assign all devices, gateway and route pattern to partition B, and so on.
03-01-2007 05:59 AM
thanks,
i created a device pool for each location, but unfortunatly there is no item on device pool menu to link it to partion.
for knowledge i use CM 5.04
03-02-2007 01:25 AM
please can you help me
