Sample Configuration For Voice Gateway 2851 Router
Hi Can I please obtian a smaple config for a 2851 Router acting as a voice gate way for Call Manager 5.1. I will prefer it to be based on Australia Standards. thanks Robert
Re: Sample Configuration For Voice Gateway 2851 Router
Depends if you want h323 or MGCP operation.
MGCP is preferable as the configuration is simpliifed and you don't need to configure the dial plan on the router.
Australia uses Euro ISDN, so the switch type is primary-net5
Here is a link on the gateway and CUCM configuration -
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
If you are using an Onramp 10 or 20 fractional service , we need to busy out the unusued B channels as well. Let me know if this is the case and I can provide additional details.
827
