Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
SAP R3 QoS
Hello, please anybody knows about what's the SAP R3 size packets in order to provide Bandwidth QoS?
Re: SAP R3 QoS
the following is config example from cisco press regarding SAP policing maybe helps u:
CAT3550(config)#ip access-list extended SAP
CAT3550(config-ext-nacl)# permit tcp any range 3200 3203 any
CAT3550(config-ext-nacl)# permit tcp any eq 3600 any
CAT3550(config)#class-map SAP
CAT3550(config-cmap)# match access-group name SAP
CAT3550(config)#policy-map UNTRUSTED-SERVER
CAT3550(config-pmap)#class SAP
CAT3550(config-pmap-c)# set ip dscp 25 ! SAP is marked as Mission-Critical
CAT3550(config-pmap-c)# police 15000000 8000 exceed-action policed-dscp-transmit
! Out-of-profile SAP is marked down to Scavenger (CS1)
good luck
if helpful Rate
Super Bronze
Re: SAP R3 QoS
Sorry I don't, but R3 isn't real tolerant of delay or drops. Best thing would be guarantee ample bandwidth via QoS (perhaps initially 50% with CBWFQ), monitor actual bandwidth demand of R3 in your environment, then adjust bandwidth guarantee.
847
