Save Bandwidth / Enable voice packet compression For GSM Gateway
please gudie me how can we enable voice packet compression in Asterisk/Voipswitch with G729/G723 codecs baiscally i want to compress voice packets in to 8/10kbps how can i do this please guide me awaiting thanks.
Re: Save Bandwidth / Enable voice packet compression For GSM Gat
Select G729 and G723 as preferred codecs.
Asterisk example:
[general]
allowsubscribe=yes
notifyringing=yes
subscribecontext=blf
callcounter=yes
counteronpeer=yes
notifycid=ignore-context
srvlookup=yes
context=default                                          ; Default context for incoming calls
allowguest=no                                           ; Allow or reject guest calls (default is yes)
localnet=192.168.2.0/255.255.255.0            ; RFC 1918 addresses
nat=yes                                                    ; there is not NAT between phone and Asterisk
dtmfmode=RFC2833                                  ; either RFC2833 or INFO for the BudgeTone
relaxdtmf=yes
context=default
allowtransfert=yes
language=it
binport=5060
bindaddr=0.0.0.0
disallow=all
allow=g729     ;in * require license see http://www.voip-info.org/wiki/view/Asterisk+G.729+pass-thru
allaw=G723.1   ;in * require license see http://www.voip-info.org/wiki/view/Asterisk+G.723+pass-thru
Cisco voice gateway example:
voice class codec 10
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g723ar63
codec preference 4 g723ar53
codec preference 5 g723r63
codec preference 6 g723r53
Regards.
Thanks bro for reply,
can you please tell me how mcuh bandwidth that i will need with that method for 32 Ports with g729 codect, and i am using GOIP GSM Gateway...and may ihave your skype ?
The bandwidth used during a call is the sum of some parameters:
audio codec (e.g. G.729) + RTP header + UDP header + IP header + layer 2 header (e.g. ethernet).
A call in G.729 over ethernet uses 31.2 Kbps per direction:
A -----------> B 31.2 Kbps
A <----------- B 31.2 Kbps
So, how many concurrent calls do you need?
32 * 31.2 kb/s =  about 1 Mbit/s upload and download.
You can reduce bandwidth consumption enabling voice activity detection (VAD or silence suppression). In this case no packets are sent during silence. This technic could decrease the quality of a call introducing a little "silence hole" at the begining of the speak.
You can find more info here: http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
Regards.
539
