SCCP Gateway issue.
hi
I am having some problems with SCCP gateway
My analog phone doesnt have any tone when i configure it through SCCP gateway
Need help dont know where am i making mistake
  • IP Telephony
1 ACCEPTED SOLUTION
VIP Super Bronze
Can you send the output of
Your config is missing the stcapp ccm-group command..
example:
stcapp ccm-group 1
stcapp
dial-peer voice 10 pots
 service stcapp
 port 2/1
if it still doesnt work please send the output of the following please
sh diag
show sccp
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Is the gateway registered to
Is the gateway registered to the CUCM? Have the endpoints been created on CUCM as skinny endpoints? What is their registration status?
Hi SreekanthWell my end point
Hi Sreekanth
Well my end point is registered to CUCM i have attached file as well give it a look as well
VIP Super Bronze
example:
stcapp ccm-group 1
stcapp
 service stcapp
 port 2/1
sh diag
show sccp
Hi Ayodeji OladipoThanks a
Hi Ayodeji Oladipo
Thanks a lot for showing your concern
below are the out puts of the commands
Show Diag
Slot 0:
        C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        Onboard VPN             : v2.2.0
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC12523RF2
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26921-04
        Board Revision           : E0
        Deviation Number         : 0
        Fab Version              : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20081225
        Chassis Serial Number    : FTX1302A4KF
        Chassis MAC Address      : 0024.14f6.7f60
        MAC Address block size   : 32
        CLEI Code                : COMV410ARA
        Product (FRU) Number     : CISCO2821
        Part Number              : 73-8853-05
        Version Identifier       : V05
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 32 35 32 33 52 46 32 40
          0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 04 42 45 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 6A 49 C2 8B 46 54 58 31 33 30 32
          0x40: 41 34 4B 46 C3 06 00 24 14 F6 7F 60 43 00 20 C6
          0x50: 8A 43 4F 4D 56 34 31 30 41 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
          0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8539-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC12501KBG
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-32
        Version Identifier       : V01
          0x00: 04 FF 40 03 EE 41 04 00 82 49 21 5B 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 35 30
          0x20: 31 4B 42 47 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 33 32 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        FXS Voice daughter card (4 port)
        Hardware Revision        : 3.1
        Part Number              : 73-6918-02
        Board Revision           : F0
        Fab Version              : 02
        PCB Serial Number        : FOC1251535N
        RMA History              : 00
        Top Assy. Part Number    : 800-17016-02
        Connector Type           : 01
        CLEI Code                : IP9IABYCAA
        Product (FRU) Number     : VIC-4FXS/DID=
          0x00: 04 FF 40 00 3A 41 03 01 82 49 1B 06 02 42 46 30
          0x10: 88 00 00 00 00 02 02 C1 8B 46 4F 43 31 32 35 31
          0x20: 35 33 35 4E 03 00 81 00 00 00 00 04 00 C0 46 03
          0x30: 20 00 42 78 02 05 01 C6 8A 49 50 39 49 41 42 59
          0x40: 43 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 1:
        Board Revision           : F0
        Fab Version              : 02
        PCB Serial Number        : FOC123702Q1
        RMA History              : 00
        Connector Type           : 01
          0x10: 88 00 00 00 00 02 02 C1 8B 46 4F 43 31 32 33 37
          0x20: 30 32 51 31 03 00 81 00 00 00 00 04 00 C0 46 03
        WIC Slot 2:
        Board Revision           : F0
        Fab Version              : 02
        PCB Serial Number        : FOC12424CZ9
        RMA History              : 00
        Connector Type           : 01
          0x10: 88 00 00 00 00 02 02 C1 8B 46 4F 43 31 32 34 32
          0x20: 34 43 5A 39 03 00 81 00 00 00 00 04 00 C0 46 03
WIC Slot 3:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC12513GF0
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
HLOP2821#sh sccp
SCCP Admin State: UP
Gateway IP Address: 192.168.1.254, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.1.150, Port Number: 2000
                Priority: N/A, Version: 5.0.1, Identifier: 2
Call Manager: 192.168.1.50, Port Number: 2000
                Priority: N/A, Version: 4.0, Identifier: 1
Alg_Phone Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.1.50, Port Number: 2000
TCP Link Status: CONNECTED, Device Name: AN2414F67F61100
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
AutoCfg_Virtual_Endpoint Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Device Name: AN2414F67F61FFF
Reported Max Streams: 0, Reported Max OOS Streams: 0
VIP Super Bronze
From you sh diag, I can see
From you sh diag, I can see that you only have 32 channel DSP. How many PRI channels did you configure on the gateway? You have 12 FXS ports and 1 E1/T1 card. That suggest to me that you need atleast 64 channel DSP to support all of these cards.
Hello!Please, post
Hello!
Please, post configuration of your gateway.
Kirill
Hi Kirill,Thanks for showing
Hi Kirill,
Thanks for showing your concern
Well i am going to paste the configuration of gateway and SCCP as well.
Well i made my router as gateway which is 2821.
Router (Gateway) Configuration
stcapp
voice-card 0
 no dspfarm
voice service voip
 modem passthrough nse codec g711ulaw
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
 timeouts initial 60
 timeouts interdigit 60
 timeouts ringing infinity
 caller-id enable
voice-port 0/2/1
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.1.50
ccm-manager sccp local GigabitEthernet0/1
ccm-manager sccp
mgcp
mgcp call-agent 192.168.1.50 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp ccm 192.168.1.150 identifier 2 version 5.0.1
sccp ccm 192.168.1.50 identifier 1 version 4.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
dial-peer voice 999001 pots
 service mgcpapp
 port 0/0/1
dial-peer voice 999003 pots
 service mgcpapp
dial-peer voice 3001 pots
 service stcapp
 port 0/2/0
HLOP2821#show ccm-manager
SCCP auto-configuration status
Registered with Call Manager: Yes
Local interface: GigabitEthernet0/1 (0024.14f6.7f61)
Current version-id: 1403065704-a8a3ec3b-e750-4900-86fc-e5c5e03d364e
Current config applied at: 21:37:01 UTC Jun 18 2014
Gateway downloads succeeded: 2
Gateway download attempts: 5
Last gateway download attempt:  23:25:46 UTC Jun 18 2014
Last successful gateway download: 23:25:46 UTC Jun 18 2014
Current TFTP server: 192.168.1.50
Gateway resets: 0
Gateway restarts: 1
Managed endpoints: 1
Endpoint downloads succeeded: 2
Endpoint download attempts: 2
Last endpoint download attempt:  23:25:46 UTC Jun 18 2014
Last successful endpoint download: 23:25:46 UTC Jun 18 2014
Endpoint resets: 0
Endpoint restarts: 1
FAX mode: cisco
Configuration Error History:
HLOP2821#
Make sure that there a port
Make sure that there a port has only the stcapp dial-peer and no mgcpapp dial-peer also.
Do the following debugs and see if can log any activity on the router.
debug vpm signal
debug sccp event
debug voip vtsp default
You'll be able to see if the port on the router detected the off-hook and what happens after that.
Hi SreekanthWell when i
Hi Sreekanth
Well when i execute the command debug vpm signal and i off hook my analog fone configured via MGCP shows some out put, but the one configured via SCCP doesnt give any out put
Below is output of debug SCCP events guess it shows some problem.
HLOP2821#debug sccp events
Skinny Client Control Protocol events debugging is on
HLOP2821#
Jun 19 22:42:27.939: sccpapp_process_timer_events: appl_type 4, experied_timer 3
, xlated_eve 9, state 4
Jun 19 22:42:27.939: sccp_handle_keep_alive_timeout: Handle keepalive timeout fo
r appl_type 4, state 4
Jun 19 22:42:27.939: sccp_appl_service_start_timer: Start timer type 3 with time
_out 30000ms
146
