Sccp identifer 1 version 5.0.1 command issue
hi,
I my current GW IOS doesn't not support the Identifer 5.0.1 of SCCP configuration, it only support 4.1.
I have CCM version 5.1 in central side, i would know if i configure the "version 4.1" i will have some problem with conference recourse?
thx.
1 ACCEPTED SOLUTION
Re: Sccp identifer 1 version 5.0.1 command issue
This is a known issue, you should upgrade your IOS to a version that includes the later callmanager versions. If i remember correctly, you will run into the same problem by specifying anything earlier than 5.0.1.
Simply do not go that far, that part of the command is optional.
That, or upgrade the IOS.
java
if this helps, please rate
java
www.cisco.com/go/pdi
when i delete the "version" command it doesn't register again CCM.
can you post your config?
hi, thx for the reply, i put version 4.1 to register the recource of my router in the CCM 5.1
thx.
175
