SCCP load 8.2.2
Have a CM 5.1 cluster deployed with 7941s/7961s. Server time shows correct while the phone time is offset by an hour. 7941s/7961s are running firmware version 8.2.1s (SCCP).
If I reset the phone from Callmanager, time shows up fine on the phone. If you unplug the cable on the same phone and plug it back in, time goes back by an hour.
I read some posts from this forum that 8.2.1 is supposed to have this problem fixed, but its behaviour is inconsistent. Also read that 8.2.2 should fix this. Cant find 8.2.2 firmware for download anywhere on CCO.When is the expected release date for 8.2.2 ?
Or is this is a problem that can be fixed by calling TAC and getting an ES ?
Re: SCCP load 8.2.2
Never mind. Bugs CSCsi09102 and CSCsh12444.
I will open a case into tac to procure this updated firmware (8.2.1 ES)
Hall of Fame Super Gold
Re: SCCP load 8.2.2
Shanky here is my 5 as you seem to diag and fix your own problems fast.
Re: SCCP load 8.2.2
Thanks Paolo, for your kind words and the 5 points. I see that 8.2(2) has been released today, so hopefully that should fix the DST issue on the 41/61s.
114
