Community Member
SCCP Phones on CUCM 9.X dealy 8-10 sec before dial
Dear all
We have cucm version 9.x and all the phones (6921,89xx) have a delay 8-10 sec to dial the internal extension numbers.
Conditions:
First , push the loud speaker  and then dial the extension has a delay (8-10 sec)  before to hear the ringtone ( it like the phone waiting for inter digit timeout.
Second condition if we dial the extension and then push the loud speaker then we don't have any delay to the dial..Its going directly
The phones are registered into CUCM via sccp
Any thoughts?
Igrusila
Hi.This because there could
Hi.
This because there could be an overlapping dialplan.
Try to go on "call routing" menu and then "route plan report" and check if you see the called extension in different partitions.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Community Member
Hi CarloThis was my first
Hi Carlo
This was my first check
There is no overlaping
We have 10 different locations and all the locations have their extension plan
551x
552x
553x
554x
etc
all the locations have the same behavior.
any other thought?
Hi.Which firmware are those
Hi.
Which firmware are those phones running.
Let me know
Carlo
Community Member
All have The latest version
6921 have: SCCP69xx.9-4-1-3SR1
HiThrough Cisco Unified
Through Cisco Unified Serviceability, select "tools" and "Dialed Number Analyzer" and fill all needed fields with correct info.
After that, please post a screenshot of the resulting page expanding "call flow" and "route pattern" sub result.
When you press # at the end
When you press # at the end of digit by digit dial , do you still see the delay ?
Did you check your whole dial
Did you check your whole dial plan??? anything that might contain wildcards and be a match??
Or only for patterns that look like what you're dialing??
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Igrusila,Can you provide
Hi Igrusila,
Can you provide the following information for a test call with this issue.
>> Calling and called party numbers
>> CSS applied on calling party and the partitions contained in that css, also provide the partition applied on called party
>> Route Plan report
As a test, can you create a new partition ( PT-TEST ) and a new CSS ( CSS-TEST ). Add PT-TEST to CSS-TEST. Now apply CSS-TEST to a DN and try calling a DN which has PT-TEST applied to it. This will rule out any overlapping dialplan issue and you can collect detailed callmanager traces for the call if the issue persists and post it on the forum.
Manish
Change the Digit Analysis
Change the Digit Analysis Complexity CallManager Service Parameter to "TranslationAndAlternatePatternAnalysis" on all nodes then pull the CallManager traces for one of these calls.
127
