Community Member
sccp/sip shared line on srst
We have both sccp and sip phones with shared lines.  When on SRST only the sccp shared line will ring for an inbound call but not the sip shared line.  Is there a way to make this work or is this not supported?
Manish
Can you post your config
Can you post your config?
Yosh
HTH Regards, Yosh
Community Member
Here is the pertinent config.
Here is the pertinent config...
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol cisco
 sip
  registrar server
  midcall-signaling passthru
voice register global
 max-dn 144
 max-pool 42
 dialplan-pattern 1 312555.... extension-length 6 extension-pattern 21....
 application app.sip
voice register pool  1
 id network 10.109.0.0 mask 255.255.0.0
 dtmf-relay rtp-nte
 call-forward b2bua busy 214005
 call-forward b2bua noan 214005 timeout 10
 codec g711ulaw
 no vad
voice-card 0
application
 global
  service alternate default
dial-peer voice 1 pots
 destination-pattern 91[2-9]..[2-9]......
 port 0/0/0:23
 forward-digits 11
dial-peer voice 2 pots
 destination-pattern 9011T
 port 0/0/0:23
 prefix 011
dial-peer voice 3 pots
 destination-pattern 9[2-9]11
 port 0/0/0:23
 forward-digits 3
dial-peer voice 100 pots
 incoming called-number 312555....
 direct-inward-dial
 port 0/0/0:23
call-manager-fallback
 secondary-dialtone 9
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 10.9.176.135 port 2000
 max-ephones 42
 max-dn 144
 transfer-pattern .T
 voicemail 214005
 alias 1 0 to 214005
 call-forward busy 214005
 call-forward noan 214005 timeout 15
At a bare minimum, you need
At a bare minimum, you need to make sure your gateway is configured to function as a SIP Registrar Server for the phones. You can achieve this under the 'voice service voip' section.
>enable
#conf t
#(conf) voice service voip
#(conf-voi-srv-voip) sip
#(conf-voi-srv-voip-sip) registrar server [expires [max sec] [min sec]]
If you already have this, then throw up your config so we can break it down and troubleshoot.
-Tony
Community Member
Hi Manish.
Hi Manish.
Did you ever get to the bottom of this? I have the same problem with a 9971 and a 7925. In SRST they both register with the shared DN, but if you call the DN, one time the 9971 will only alert and the next time only the 7925 will alert?
Hi Tim,
Hi Tim,
As per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#pgfId-1081127
Configuring a Mixed Shared Line
To configure a mixed shared line between Cisco Unified SIP IP and Cisco Unified SCCP IP phones, perform the following steps.
Prerequisites
Cisco Unified CME 9.0 or a later version.
Restrictions
  • Cisco Unified SCCP trunk-dn is not supported.
  • Mixed shared lines can only be configured on one of several common directory numbers.
  • Mixed shared lines are not supported in Cisco Unified SRST.
Manish
Community Member
Thanks Manish.
Thanks Manish.
I think I am safe in assuming I need to be using CME as SRST and not CallManager fallback like I am now for this to work?
Community Member
Apologies, just read the last
Apologies, just read the last line of the restrictions:-
854
