SCCP Transcoders and Conference doesn't register.
Dear Friends,
I having a strange issue, I have configured my 3945 GW with SCCP for Conferencing and Transcoding. Also on the CUCM Side, i have used the Cisco IOS Enhanced media termination Point for this setup but I see the transcoders are not getting registered. I had reset the items from both the sides but No luck.
In the "Debug SCCP all" i do see error 257 in socket.
The configs:
sccp local GigabitEthernet0/2
sccp ccm 19.106.182.15 identifier 2 version 7.0
sccp ccm 19.106.214.15 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/2
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register CFB-12345678901
associate profile 1 register XCD-12345678901
dspfarm profile 1 transcode
description #XCODE dsp farm - G711/G729r8 only#
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 30
associate application SCCP
dspfarm profile 2 conference
description Ad-hoc conference - G711 only
codec g711ulaw
codec g711alaw
maximum sessions 8
DEBUG sccp all:
Jan 14 15:20:13: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 2, appl_type 3
Jan 14 15:20:13: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr 19.106.214.15, priority 1, port 2000
Jan 14 15:20:13: sccp_appl_service_start_timer: Start timer type 1 with time_out 30000ms
Jan 14 15:20:13: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 3, prof_id 2, to ipaddr 19.106.214.15
Jan 14 15:20:13: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 3, appl profile 2
Jan 14 15:20:13: sccp_tcp_open_and_set_option: Socket 1 opened and binded to addr 19.106.214.15 - for appl_type 3, prof_id 2
Jan 14 15:20:13:  sccp_socket_connect_to_ccm :: connecting to port 2000 sccp_socket_connect_to_ccm: soc conn to 19.106.214.15 port 2000 in progressfor appl_type 3, state 1, soc_fd 1 appl 144C622C
Jan 14 15:20:13: sym_xapp_xlate_ccapi_eve: Unsupported ccapi eve 2
Jan 14 15:20:13: sym_xapp_process_ccapi_events: Unsupported ccapi eve_id 2
Jan 14 15:20:13: sccpapp_process_socket_events: appl_type 2, soc_fd 0, soc 0, swb_soc -1
Jan 14 15:20:13: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 2, eve 4, state 1
Jan 14 15:20:13: sccp_appl_service_stop_timer: Stop 2064E60 timer
Jan 14 15:20:13: sccp_process_socket_connect_result: appl 2064E08, soc_recv err 257, len -1, appl_type 2
Jan 14 15:20:13: sccp_process_socket_connect_result: appl_type 2, eve 1, soc_id -1, state 1
The SCCP State is Up...
fingw001-vg3945#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/2
        IPv4 Address: 19.155.95.198
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 19.106.182.15, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 2
                Trustpoint: N/A
Call Manager: 19.106.214.15, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 60, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Reported Max Streams: 64, Reported Max OOS Streams: 0
TLS : ENABLED
Hi Mohsin,
Apart from ensuring that TCP port 2000 is not blocked between cucm and this gateway, the only other thing that i would like to ensure is that the names of transcoder and conference bridge used on cucm configuration page is the same as configured on the gateway i.e CFB-12345678901 and XCD-12345678901.
Manish
Hi Manish,
I did a telnet to the CUCM IP from the GW sourcing the GI0/2. Its open and also to make sure I am configuring it correct on the CUCM. I did delete the Xcoder on the CUCM and configured it from copying from the GW and pasted in the CUCM. But no Luck
fingw001-vg3945#telnet 19.106.182.12 2000 /source-interface gigabitEthernet 0/2
Trying 19.106.182.12, 2000 ... Open
^C^X
[Connection to 19.106.182.12 closed by foreign host]
fingw001-vg3945#
Can you please post the running config from the gateway and a screenshot of the cucm page showing xcoder config.
Manish
fingw001-vg3945#sh running-config
Building configuration...
Current configuration : 25223 bytes
! Last configuration change at 13:06:36 UTC Tue Jan 14 2014 by kmohsin
! NVRAM config last updated at 12:22:27 UTC Tue Jan 14 2014 by skarth43
version 15.1
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname fingw001-vg3945
boot-start-marker
boot system flash:c3900-universalk9-mz.SPA.151-3.T2.bin
boot-end-marker
logging buffered 16384
no logging console
enable secret 5 $1$OFF8$8Z8jdwPVNpsGaUg4DYXR11
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization commands 0 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting update newinfo
aaa accounting commands 15 default
action-type start-stop
group tacacs+
aaa session-id common
errdisable recovery cause udld
errdisable recovery cause rootguard
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery interval 60
no ipv6 cef
no ip source-route
ip cef
ip multicast-routing
ip domain list nls.ford.com
ip name-server 19.155.192.72
ip name-server 19.175.128.73
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice dsp crash-dump file-limit 3
voice dsp crash-dump destination flash:dsp-crash
voice service voip
ip address trusted list
  ipv4 19.106.182.0 255.255.255.0
  ipv4 19.106.214.0 255.255.255.0
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  header-passing
  error-passthru
  asserted-id pai
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
  sip-profiles 1
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class sip-profiles 1
request INVITE sip-header Supported remove
request INVITE sip-header Min-SE remove
request INVITE sip-header Session-Expires remove
request INVITE sip-header Unsupported modify "Unsupported:" "timer"
request ANY sip-header Allow-Header modify ", UPDATE" ""
response ANY sip-header Allow-Header modify ", UPDATE" ""
voice translation-rule 1
rule 1 /\(^...$\)/ /7319\1/
voice translation-rule 2
rule 1 /^103447\(...$\)/ /7319\1/
voice translation-rule 3
rule 1 /^7319\(...$\)/ /103447\1/
voice translation-rule 4
rule 1 /^9\(.*\)/ /\1/
voice translation-profile Internal-to-PhoneDN
translate called 1
voice translation-profile PSTN-to-PhoneDN
translate called 2
voice translation-profile PhoneDN-to-PSTN
translate calling 3
translate called 4
application
package callfeature
  param med-inact-det enable
  param med-inact-disc-cause 44
  param med-inact-action disconnect
global
  service alternate DEFAULT
license udi pid C3900-SPE150/K9 sn FOC174198Z0
license accept end user agreement
hw-module pvdm 0/0
vtp domain fingw001-vg3945
vtp mode transparent
redundancy
ip tcp path-mtu-discovery age-timer 30
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description rhost="finfw001" rint="G1/0"
ip address 19.155.95.206 255.255.255.252
duplex auto
speed auto
service-policy input EdgeMark2
description rhost="finrs001" rint="G3/22"
ip address 19.155.95.198 255.255.255.252
no ip redirects
duplex auto
speed auto
ip forward-protocol nd
no ip pim dm-fallback
ip pim autorp listener
no ip http server
no ip http secure-server
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/2
ip flow-export version 5
ip flow-export destination 19.97.9.164 9995
ip route 0.0.0.0 0.0.0.0 19.155.95.197
ip route 10.80.144.0 255.255.255.0 19.155.95.205
ip route 192.168.13.232 255.255.255.252 19.155.95.205
ip tacacs source-interface GigabitEthernet0/2
ip access-list extended Virus_LAN
deny   53 any any
deny   55 any any
deny   77 any any
deny   pim any any
deny   tcp any any eq 5554
deny   tcp any any eq 8594
deny   tcp any any eq 8563
permit ip any any
ip access-list extended Virus_LAN_PIM
deny   53 any any
deny   55 any any
deny   77 any any
permit ip any any
ip access-list extended Virus_Server
deny   53 any any
deny   55 any any
deny   77 any any
deny   pim any any
permit ip any any
ip access-list extended Virus_Server_PIM
deny   53 any any
deny   55 any any
deny   77 any any
permit ip any any
ip access-list extended Virus_WAN
deny   53 any any
deny   55 any any
deny   77 any any
deny   pim any any
deny   udp any any eq 1434
permit ip any any
ip access-list extended Virus_WAN_PIM
deny   53 any any
deny   55 any any
deny   77 any any
permit ip any any
ip sla responder
logging trap debugging
logging source-interface GigabitEthernet0/2
logging 19.97.9.50
logging 19.97.9.80
access-list 4 remark - SNMP access for NMS subnet
access-list 4 permit 19.97.9.0 0.0.0.255
access-list 9 remark - SNMP access for HP DDMA subnets
access-list 9 permit 19.106.113.16 0.0.0.15
access-list 9 permit 19.106.113.32 0.0.0.15
access-list 9 permit 19.106.117.16 0.0.0.15
access-list 9 permit 19.106.117.32 0.0.0.15
access-list 9 permit 19.110.113.16 0.0.0.15
access-list 9 permit 19.110.113.32 0.0.0.15
access-list 9 permit 19.110.117.16 0.0.0.15
access-list 9 permit 19.110.117.32 0.0.0.15
access-list 141 remark * Iron class - Interactive Queue (IP Precedence 1)
access-list 141 remark - generic TCP traffic, excludes Internet web & C3P Metaphase Mux
access-list 141 remark - Public Internet proxy HTTP/HTTPS excluded (drops to default queue)
access-list 141 deny   tcp any any eq 83
access-list 141 deny   tcp any eq 83 any
access-list 141 remark - C3P bulk traffic port number
access-list 141 deny   tcp any any eq 4544
access-list 141 deny   tcp any eq 4544 any
access-list 141 deny   tcp any any eq 16016
access-list 141 deny   tcp any eq 16016 any
access-list 141 remark - MX2 Handhelds (intentionally one way)
access-list 141 deny   tcp any range 4000 4050 any
access-list 141 remark - The following permit catches any non-excluded TCP
access-list 141 permit tcp any any
access-list 141 remark - SNMP traffic from NetOps Mgt subnet with CS1 *
access-list 141 permit udp 19.97.9.0 0.0.0.255 any eq snmp
access-list 141 permit udp any eq snmp 19.97.9.0 0.0.0.255
access-list 141 permit udp any 19.97.9.0 0.0.0.255 eq snmptrap
access-list 142 remark * Bronze class - Interactive Queue (IP Precedence 2)
access-list 142 remark - DNS query/response, Pinnacle
access-list 142 permit udp any any eq domain
access-list 142 permit udp any eq domain any
access-list 142 remark - HTTP traffic (within Ford only)
access-list 142 permit tcp any any eq www
access-list 142 permit tcp any eq www any
access-list 142 remark - SSL Web traffic
access-list 142 permit tcp any any eq 443
access-list 142 permit tcp any eq 443 any
access-list 142 deny   tcp any any lt 1024
access-list 142 deny   tcp any lt 1024 any
access-list 142 permit tcp any any eq 8058
access-list 142 permit tcp any eq 8058 any
access-list 143 remark * Silver class - Video Queue (IP Precedence 3)
access-list 143 remark - Exclude low ports to reduce false triggers on
access-list 143 remark client random ephemeral ports
access-list 143 deny   udp any any lt 1024
access-list 143 deny   udp any lt 1024 any
access-list 143 deny   tcp any any lt 1024
access-list 143 deny   tcp any lt 1024 any
access-list 143 remark -  Devices allowed into the video queue are trusted
access-list 143 remark at source and mark IP Prec 3.   Adding "precedence flash"
access-list 143 remark to  permits excludes unplanned usage of queue.
access-list 143 remark - H.225 RAS
access-list 143 permit udp any any eq 1719 precedence flash
access-list 143 permit udp any eq 1719 any precedence flash
access-list 143 remark - H.323 control traffic
access-list 143 permit tcp any any eq 1720 precedence flash
access-list 143 permit tcp any eq 1720 any precedence flash
access-list 143 remark - H.245 control traffic
access-list 143 permit tcp any any range 5555 5560 precedence flash
access-list 143 permit tcp any range 5555 5560 any precedence flash
access-list 143 permit tcp any any range 11000 11999 precedence flash
access-list 143 permit tcp any range 11000 11999 any precedence flash
access-list 143 remark - SCCP (skinny) traffic
access-list 143 permit tcp any any range 2000 2002 precedence flash
access-list 143 remark - Video & Audio RTCP traffics, MGCP (UDP:2427)
access-list 143 permit tcp any any range 2326 2331 precedence flash
access-list 143 permit tcp any range 2326 2331 any precedence flash
access-list 143 permit udp any any range 2327 2499 precedence flash
access-list 143 permit udp any range 2327 2499 any precedence flash
access-list 143 remark - Secure SCCP (skinny) traffic
access-list 143 permit tcp any any eq 2443 precedence flash
access-list 143 remark - Secure and non-secure SIP traffic
access-list 143 permit tcp any any range 5060 5061 precedence flash
access-list 143 permit tcp any range 5060 5061 any precedence flash
access-list 143 permit udp any any range 5060 5061 precedence flash
access-list 143 permit udp any range 5060 5061 any precedence flash
access-list 143 remark - Avaya IP telephony control signaling
access-list 143 permit tcp any any range 5010 5012 precedence flash
access-list 143 permit tcp any range 5010 5012 any precedence flash
access-list 144 remark * Gold class - Interactive Queue (IP Precedence 4)
access-list 144 remark - SQL*Net
access-list 144 permit tcp any any eq 66
access-list 144 permit tcp any eq 66 any
access-list 144 remark - Telnet
access-list 144 permit tcp any eq telnet any
access-list 144 permit tcp any any eq telnet
access-list 144 remark - Altel TN3270
access-list 144 permit tcp any any eq 1023
access-list 144 permit tcp any eq 1023 any
access-list 144 deny   tcp any any lt 1024
access-list 144 deny   tcp any lt 1024 any
access-list 144 remark - DLSw
access-list 144 permit tcp any eq 2065 any
access-list 144 permit tcp any any eq 2065
access-list 144 permit tcp any any eq 1521
access-list 144 permit tcp any eq 1521 any
access-list 144 remark - Ford TN3270
access-list 144 permit tcp any any eq 5031
access-list 144 permit tcp any eq 5031 any
access-list 144 remark - Deny multicast and mark lightweight wireless CAPWAP control traffic
access-list 144 deny   udp any 224.0.0.0 15.255.255.255
access-list 144 permit udp any any eq 5246
access-list 144 permit udp any eq 5246 any
access-list 145 remark * Platinum class - Voice Queue (IP Precedence 5)
access-list 145 remark - Exclude low ports to reduce false triggers on client random ephemeral ports
access-list 145 deny   udp any any lt 1024
access-list 145 deny   udp any lt 1024 any
access-list 145 remark - voice RTP packets
access-list 145 permit udp any any range 16384 32767 dscp ef
access-list 145 permit udp any range 16384 32767 any dscp ef
access-list 146 remark * Internet class - Routing Queue (Trust Marking)
access-list 146 remark - Routing protocols: OSPF, EIGRP, BGP
access-list 146 permit ospf any any
access-list 146 permit eigrp any any
access-list 146 permit tcp any any eq bgp
access-list 146 permit tcp any eq bgp any
access-list 146 remark - Lightweight wireless CAPWAP data traffic
access-list 146 permit udp any any eq 5247
access-list 146 permit udp any eq 5247 any
access-list 148 remark * Mcast class - Interactive Queue (IP Precedence 1)
access-list 148 permit udp any 239.80.0.0 0.0.0.127
access-list 149 remark * IP_Video class - Video Queue (IP Precedence 4)
access-list 149 remark - Exclude low ports to reduce false triggers on client random ephemeral ports
access-list 149 deny   udp any any lt 1024
access-list 149 deny   udp any lt 1024 any
access-list 149 permit udp any any range 2326 2498 dscp af41
access-list 149 permit udp any range 2326 2498 any dscp af41
nls resp-timeout 1
cpd cr-id 1
snmp-server community B1K7PD3L RO 9
snmp-server ifindex persist
snmp-server trap-source GigabitEthernet0/2
snmp-server location addr Bldg Abbr"FCEFFI" (7007) Bldg name "Ford Finland & FORSO Address: Plaza Business Park Building Halo  Ayritie 24 City: Vantaa Finland 01510
snmp-server contact name ="Jere Vastaki" Fordnet"7319152" Phone"358-9-35170152" CDS"jvastama"
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps envmon
snmp-server enable traps bgp
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps hsrp
snmp-server host 19.97.9.134 fordsnmp
snmp-server host 19.97.9.135 fordsnmp
tacacs-server host 19.97.9.193
tacacs-server host 19.97.9.202
tacacs-server timeout 10
tacacs-server key 7 1335051718180D2E2223212734364315
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp profile default
sccp
sccp ccm group 1
associate profile 2 register CFB-FINGW001EU2
associate profile 1 register XCD-FINGW001EU2
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 30
codec g711ulaw
codec g711alaw
maximum sessions 8
dial-peer voice 3501 voip
tone ringback alert-no-PI
description Incoming from PSTN/SIP provider
translation-profile incoming PSTN-to-PhoneDN
session protocol sipv2
incoming called-number .T
voice-class codec 1
voice-class sip early-offer forced
voice-class sip profiles 1
dtmf-relay rtp-nte digit-drop
ip qos dscp cs3 signaling
no vad
dial-peer voice 3601 voip
description incoming from CUCM-SIP Trunk
incoming called-number 9T
voice-class codec 1
dtmf-relay rtp-nte sip-notify
no vad
dial-peer voice 4501 voip
description Outgoing PSTN/SIP provider
translation-profile outgoing PhoneDN-to-PSTN
destination-pattern 9T
session target ipv4:10.80.144.10
voice-class codec 1
voice-class sip options-keepalive
no vad
dial-peer voice 4601 voip
description Outgoing CUCM-SIP Trunk to CUCM Subscriber 1
preference 1
destination-pattern 7319...$
session target ipv4:19.106.214.15
voice-class codec 1
dtmf-relay sip-notify rtp-nte
no vad
dial-peer voice 4602 voip
description Outgoing CUCM-SIP Trunk to CUCM Subscriber 2
preference 2
session target ipv4:19.106.182.15
voice-class codec 1
no vad
dial-peer hunt 1
gateway
media-inactivity-criteria all
timer media-inactive 5
timer receive-rtp 1200
sip-ua
set pstn-cause 1 sip-status 503
set pstn-cause 3 sip-status 503
retry invite 2
retry bye 2
retry cancel 2
timers trying 550
g729-annexb override
gatekeeper
shutdown
banner motd ^C
WARNING! THIS IS A PRIVATE COMPUTER SYSTEM. USAGE MAY BE
MONITORED AND UNAUTHORIZED ACCESS OR USE MAY RESULT IN
CRIMINAL OR CIVIL PROSECUTION.
Except for some privacy rights granted by applicable law,
by signing on to the system you acknowledge:
You do not have any expectation of privacy in your use of the system.
You are familiar with, understand, accept, and will comply with the
provisions of Company Directive B-109.
^C
line con 0
exec-timeout 20 0
password 7 045307225A7364775E4A03
transport preferred none
line aux 0
exec-timeout 20 0
line vty 0 4
exec-timeout 20 0
password 7 060E0305191C2120524414
transport input telnet
scheduler allocate 20000 1000
ntp server 19.211.4.1
ntp server 19.211.5.1
end
fingw001-vg3945#
fingw001-vg3945#
VIP Super Bronze
Ensure that the cucm servers configured in your sccp configuration are also the same servers in the cucm group assigned to the CFB and Xcoder...
Then try a conf t, no sccp, sccp ( this will reset the sccp process on the gateway)
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Config looks good, try the couple of steps suggested by aokanlawon and if the issue persists its surely going to be a network issue, as suggested by the TCP errors in the output of show sccp.
Manish
aokanlawon,
Thanks for the comment. But It was already checked but no issues found. As i mentioned while raising, it has been reset from both the sides (CUCM & GW ). Also the GW has been reloaded. I am looking some info on the  "TCP_CONN_ERROR" which I am getting on the "Show SCCP". it did checked this on forums but didn't get the valid information. Also If you could check the Debugs. I do receive the error.. Please advise..
VIP Super Bronze
Is there a firewall between the gateway and CUCM?
Yes, There is a firewall but we have ensure that the ports are unblocked thru it.. Just fyi below..
^C^X
fingw001-vg3945#
VIP Super Bronze
Can you turn on "debug ip tcp transaction" on the gateway. From the logs, the gateway doesnt seem to be able to open TCP connection to port 2000
Yes, I do see some issue in the connectivity..
Jan 14 17:21:13: TCB122D846C setting property TCP_NO_DELAY (0) 13BCE49C
Jan 14 17:21:13: TCP: Random local port generated 27178, network 1
Jan 14 17:21:13: TCB122D846C bound to 19.155.95.198.27178
Jan 14 17:21:13: TCB122D846C setting property TCP_NONBLOCKING_WRITE (10) 13BCE52C
Jan 14 17:21:13: TCB122D846C setting property TCP_NONBLOCKING_READ (14) 13BCE52C
Jan 14 17:21:13: TCB122D846C setting property TCP keepalive timeout (17) 13BCE52C
Jan 14 17:21:13: TCB122D846C setting property TCP_TOS (11) 13BCE4D0
Jan 14 17:21:13: Reserved port 27178 in Transport Port Agent for TCP IP type 1
Jan 14 17:21:13: TCP: pmtu enabled,  mss is currently set to 1460
Jan 14 17:21:13: TCP: sending SYN, seq 624419875, ack 0
Jan 14 17:21:13: TCP0: Connection to 19.106.214.15:2000, advertising MSS 1460
Jan 14 17:21:13: TCP0: state was CLOSED -> SYNSENT [27178 -> 19.106.214.15(2000)]
Jan 14 17:21:13: TCB0204FB44 setting property TCP_TOS (11) 13912CD0
Jan 14 17:21:13: TCB0204EC2C setting property TCP_TOS (11) 13912CD0
Jan 14 17:21:15: TCB0204EC2C setting property TCP_TOS (11) 13912CD0
Jan 14 17:21:15: TCB13D17D2C setting property TCP_TOS (11) 13912CD0
Jan 14 17:21:15: 19.155.95.198:27178 <---> 19.106.214.15:2000   congestion window changes
Jan 14 17:21:15: cwnd from 1460 to 1460, ssthresh from 65535 to 2920
Jan 14 17:21:15: TCP0: timeout #1 - timeout is 4000 ms, seq 624419875
Jan 14 17:21:15: TCP: (27178) -> 19.106.214.15(2000)
Jan 14 17:21:15: TCP0: ICMP destination unreachable received
Jan 14 17:21:15: Released port 27178 in Transport Port Agent for TCP IP type 1 delay 240000
Jan 14 17:21:15: TCP0: state was SYNSENT -> CLOSED [27178 -> 19.106.214.15(2000)]
Jan 14 17:21:15: TCB 0x122D846C destroyed
Jan 14 17:21:15: TCB0204FB44 setting property TCP_TOS (11) 13912CD0
Any suggestions on this? I feel to take this up with the Firewall team..
h323-gateway voip bind srcaddr 19.155.95.198
no ip redirects
duplex auto
speed auto
VIP Super Bronze
I suggest you contact the firewall team..The TCP connection is not getting established...
1340
