09-24-2013 02:24 AM - edited 03-16-2019 07:30 PM
We have updated the firmware of 7911 phones to SCCP11.9-3-1SR2-1S. The case is after update the phones, many user connected to Juniper with LDP switchs have lost the conection on their PC. I mean te phone works but the PC connected to the phone not but it has link.
We have downgrade the phone to previus version (SCCP11.9-0-2SR1S) and their are working now.
I haven't found any bug in this firmware but may be anyone knows what could be the problem.
Mean while we are going to make test with SCCP11.9-3-1SR1-1S version
Thank you.
Best Regards
09-24-2013 07:44 AM
Are you facing same issue with other phone models when upgrading the firmware ?
Vigeesh
09-24-2013 03:09 PM
what is your CCM version ?
Anas
please rate all helpful posts
09-25-2013 12:00 AM
Hi Martin,
I was trying to look into bugs related to this phone firmware but did not find any.
Do u have cisco switch just to troubleshoot?
regds,
aman
09-25-2013 01:26 AM
Thank you for the answers.
We just have had this problem with 7911. We have other models as 7962, 7965, etc with SR2 but they work well.
We had 2500 7911 phones already updated in differents branchs, but only arround 50 of them started to fail. They are connected to a Juniper Switch, this is the only difference with the others.
Were are performaning some test with SR1 and its looks work fine.
09-25-2013 03:43 AM
Unfortunally the SR1 has the same issue.
Is very strange. The users with the problem are connected to a Juniper x3200. This switch is a distribution switch. There is a Cisco 2960 as access swtich connected to the Juniper. The users in the cisco switch work well.
Also, we have others users connected to others x3200 and work fine. The only difference is these Juniper Switches work as Access swiches and the swiches with the problem work as distribution switches conected by fiber to the core and with a Cisco 2960 Access switch conected to them.
Anyone knows which is the most lower firmware we can use for 7911 phones to work in CUCM 9.1 version? becaue all of this is in order to upgrade the CUCM to 7.1 to 9.1 and 9.1 have 9.3.1SR1 firmware.
Thank you.
09-25-2013 04:02 AM
Hi Martin,
You can try downloading from the below link
Did the 7911 phones work with 9.3(1)SR1?
regds,
aman
09-25-2013 05:47 AM
Yes, we have used that firmware.
No, SR1 has the problem as well.
We though could be a problem with the lldp-med of the Juniper and the CDP of the Cisco. But we can not configure lldp-med in Cisco because i has a Lite image.
09-25-2013 06:12 AM
Hi Waldo,
Suggest opening case with Juniper.
regds,
aman
