Screen print in CUCM 7
phonetech
Does anyone know if there is a way to print a complete page in CUCM 7 administration?
A good example would be a phone display. It is a long page and you have to kind of scroll inside the browser window.
I've tried both Mozilla & IE but I can only print the visible part.
Yury
GUENTER SAUTER
Hi Yury,
I use the tool Snagit from Techsmith. With this you can capture scolling windows.
http://www.techsmith.com/screen-capture.asp
It's not for free, but the trial version runs for 30 days.
Best regards,
Guenter
Thanks, I'll give it a try.
I have Snagit at work and use the scrolling window capture to grab full pages in CUCM no problem in one shot!
