Community Member
Scripting CUCM Install
are there any resources you can point me to so that I could learn how to script portions of the CUCM install if possible. I would like to be able to populate the database in a bit more automated way. Looking at 7.X and above.
1 REPLY
Re: Scripting CUCM Install
CUCM 7.X is improved BAT tremedously. You can export alot of information. Customize it and import into a new system. You can create template based on this. Take a look at the BAT export options.. It works great..
132
