Community Member
SD button - CP7975, CUCM6.1
Hi!
When I configure an SD button the phone shows a gray color line. The client as an image background and he would like to have only the SD Label but not the gray line. How can I change this?
Ana
1 ACCEPTED SOLUTION
Re: SD button - CP7975, CUCM6.1
sorry, that's WAD (working as designed) the behavior cannot be changed, they'll have to live with that.
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Community Member
OK. Thanks. What about the grey that it fills between lines? Is it also unchangeable?
Ana
115
