09-03-2014 03:12 PM - edited 03-17-2019 12:01 AM
Hi all
after configuring the SIP trunk to ITSP some calls to some numbers gives fast busy tone, so after checking the logs we got the following :
Sent:
INVITE sip:sip:3333333@10.208.9.69:5060 SIP/2.0
Via: SIP/2.0/UDP 192.29.55.102:5060;branch=z9hG4bK378DEDE
Remote-Party-ID: "TEST A"<sip:2222222@192.29.55.102>;party=calling;screen=yes;privacy=off
From: "TEST A"<sip:2222222@192.29.55.102>;tag=658BEE34-22E5
To: <sip:3333333@10.208.9.69>
Date: Tue, 02 Sep 2014 07:17:34 GMT
Call-ID: B6FE096-31A811E4-A371D48D-F9AAAD14@192.29.55.102
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3158903424-0000065536-0000009367-0019441856
User-Agent: Cisco-SIPGateway/IOS-15.2.1.T4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1409642254
Contact: <sip:2222222@192.29.55.102:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
Session-Expires: 1800
Content-Length: 0
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 503 Service Unavailable
Record-Route: <sip:10.208.9.69:5060;transport=udp;lr>
To: <sip:3333333@10.208.9.69>;tag=sbc0806ifmsh3is
CSeq: 101 INVITE
Reason: Q.850;cause=41;text="temporary failure"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
and when we contacted the ITSP for This "Temporary Failure" they said that they are not receiving any SDP with the early media , but as you can see this is a delayed offer as it is the default behavior of CUCM.
how can we change the CUCM to early media with SDP without using MTP?
Notes:
calls to other numbers going from the same outgoing dial-peer are working with no issue
(we are using CUCM 10.5)
Thanks in advance
Solved! Go to Solution.
09-03-2014 03:53 PM
Under the SIP profile, there is a setting to enable Early Offer - best effort. This will not insert MTP. Create a new SIP profile and make changes to that profile and assign it to the SIP trunk.
You could also force early offer on the CUBE by adding the command 'early-offer forced'.
09-03-2014 03:53 PM
09-04-2014 06:13 AM
Thank you very much i already did that today and it worked
but i want to know why this is only happening with some calls only ?
