search filter CUCM
a.gooding
Level 5
Level 5
Guys,
im a little embarrassed to say that i have no idea on using the serach filter capability to do bulk updates. i need to update extensions 1006 to 1019 for a new pickup group. i go to bulk admin, phones, add/update lines and i cannot filter to the exact range i require.
can anyone assist?
Jaime Valencia
Go to BAT, and use
Find Update Phones Query where
DN option and configure 2 of them
100[6-9]
Press the + sign and add the other clause
101X
Make sure to change the Using to OR instead of AND.
Or simply do the process twice, one per range
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
i know that probably seemed simple for the average person but i just dont get it.
ok so i want to do an update from 1006 - 1019
can you walk me though step by step?
