Searching Call Manager directory by number
System:
CCM 4.14(b) running on Win2K.
For the longest time, any attempt to search the system directory by number results in a "No Records Match" error.
Searching by this criteria *did* work at one time.
Any ideas as to where to start looking?
Green
Re: Searching Call Manager directory by number
that CCM version does not exist
Please clarify
You can look for DN is SQL DB
(Numplan( table
Sorry, slip of the finger.
I meant CCM 3.1(4b).
as Gonzalo mentions you can look in the numplan table for the DNs, the field name is DNorPattern
java
if this helps, please rate
www.cisco.com/go/pdi
159
