Second line ring on cucm 7.1
Chris Plesco
Hi Everyone,
I just migrated from ccm 4.1 to 7.1 and am learning there are a few differences.  Do you know if I should be able to have a second ring?  Any dn on the second line appearance does not seem to ring.  If this is the case, then what is the use of having a 2 line phone?
Thanks for your help
Chris
Rob Huffman
Hi Chris,
Yes, this should be most possible
Have a look at the second line on one of the non-functioning phones and
check the (under DN config page);
Ring Setting (Phone Idle) =
Ring Setting (Phone Active) =
Let us know what those are set as.
Cheers!
Rob
Rob Huffman
Hi Chris,
Cheers!
Rob
Hi Rob,
Thanks for letting me know it was possible.  I just found i had the phone in the wrong partition.
Thanks a ton!
Chris
Hey Chris,
You are always welcome my friend Not much help, but I'm glad
you got this sorted ...great work!
Cheers!
Rob
