05-06-2014 08:35 AM - edited 03-16-2019 10:41 PM
I do not deal with this often so want to make sure my logic makes sense. I have a site that currently has 2 Bogen AMP's and a Bogen NR100. They are using the NR100 for paging. So they can dial a 5 digit extension to page over their existing speakers.
One AMP is used for the production speakers, the other is for the office speakers. Currently when they dial the 5 digit extension the page will go to both Office and Production.
They want a separate 5 digit extension to page only production. I think I need to purchase another NR100, connect it to the Production AMP and build out CUCM for the new 5 digit. Does that sound right?
05-06-2014 09:00 AM
That should work fine. You may want to look into getting a real paging controller in the future so you only have one device to worry about.
05-06-2014 10:02 AM
Thanks Brian.. agreed on the paging controller comment.
