04-29-2014 02:09 PM - edited 03-16-2019 10:37 PM
Hello.
I have the next situation. I have cisco ata187 and a phone on it. It is registered to cme 9.1. No problems to configure one telephone number per one analog line. But my boss wants also to have the second private number on the same analog phone. How can I do it? If it is not possible on ata187, what adapter do i need?
Solved! Go to Solution.
04-29-2014 05:36 PM
If this is the purpose just to receive calls for multiple numbers on a single ATA port you can use number expansion (num-exp global config) but to make calls the extension will be announced to what ever the ATA port is.
Please rate helpful posts.
04-29-2014 05:36 PM
04-30-2014 01:42 PM
Thanks. That worked)))
