Secondary number on 7911 phone in a CUCM 8.X
is it possible to add a  Secondary number on 7911 phone in a CUCM 8.X.like adding secondary number in CCME
ex:number          1001 secondary 4805551001
thanks
Alan
Super Bronze
Typically you would add those secondaries under CME to allow this handset to accept calls for both numbers.
On a CM system you would use a 'translation pattern' to map all the 4805551XXX numbers to 1XXX for example (or whatever matches your range of numbers).
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
There is Voice transalation pattern in CCME as well
thanks for the info
474
