Secure communication between phone and CUCM
I'm aware that you can configure Phone Proxy to encrypt the voice between IP phones and CUCM but this client is asking about a feature that allows a secure communication between a phone and the CUCM directly (without an ASA). Is there such a feature? Can't find it... thanks!
Federico.
2 ACCEPTED SOLUTIONS
Re: Secure communication between phone and CUCM
Even without ASA, the phone's SSL VPN connection would need to terminate on some sort of VPN concentrator.  The CUCM does not directly terminate VPN connections.
Hailey
Take a look here - it's a process by which you install a security certificate on the phones and allows signaling encryption, etc.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/7_0_1/secugd/secuphne.html#wp1044280
Hailey
Thank you the Phone VPN seems to be what we're looking for...
Just to make sure...
This feature allows the calls to go through SSL (without any ASA) correct?
I've found this:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_0/english/administration/guide/7970set.html#wp1271763
Federico.
I guess my question is if the SSL VPN connection from the phone terminates on the CUCM itself or requieres an ASA to terminate the AnyConnect
connection. There's no ASA, so the're looking for a VPN connection from the phones to the CUCM directly (if possible).
Federico.
Hailey
Great, thank you guys.
Federico.
298
