Security by default when migrating tio UCS server
HI,
I am currently running Call Manager 8.5.1 on a standalone MCS 7825 server. I plan to migrate from this to a UCS server. I have backed up the current server via disater recovery process and successfully restored to the new UCS server. My question is when i move the phones over to the new server, will they be able to register to it(the IP Address/ hostname is the same as old server)? Or will security by default prevent the phones from registering. My feeling is that the security by default config would migrate accross when i restore via the disater recovery process. Has anyone done this before. i have no way of testing until I do the migration.
Derek
  • IP Telephony
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: Security by default when migrating tio UCS server
Hi Derek,
Excellent question
I'm with you that the ITL files should be honored in this example....but I wouldn't
head down that path with the possible disastrous outcomes without proof. Did you look at
using the "Rollback Enterprise Parameter"??
https://supportforums.cisco.com/docs/DOC-15799
Cheers!
Rob
If you have a couple of broken phones (hookswitch etc.) you could test ahead of time
by building them on the production network and then moving them to the lab.
"Always movin' ahead and never lookin' back" - Springsteen
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
To add to Robs answer, the rollback option is the safest.  Depending on what version of 8.5.1 there is a bug where the DRF process do not backup certificates properly so even after a restore phones will not register correctly to the new server even though it has the same IP address because the certificates change.
CUCM DRF Backup does not backup certificates
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtn50405
Hi Derek,
Excellent question
Cheers!
Rob
I migrated over to the UCS environment and the weekend and the certificates migrated accross via the diasaster recovery restore process. All phones registered correctly. I am running 8.5.1. Thanks for your help
205
