Security concern in CME 4.0
Why are tcp ports 1720 and 2000 listenig on interface ATM0/1/0.2 in this configuration?
What are the risks?
Should I use an access-list to protect them?
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-10,16
vlan internal allocation policy ascending
interface GigabitEthernet0/0
ip address 192.168.144.158 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
duplex auto
speed auto
no mop enabled
h323-gateway voip interface
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.2 point-to-point
ip address 80.x.x.103 255.255.255.0
ip mtu 1492
ip nat outside
no snmp trap link-status
pvc 8/32
encapsulation aal5snap
ip route 0.0.0.0 0.0.0.0 80.80.80.2
dial-peer voice 2 voip
destination-pattern .T
session target ipv4:192.168.144.158
dtmf-relay h245-alphanumeric
codec g711alaw
dial-peer voice 1001 pots
destination-pattern T
direct-inward-dial
port 0/0/0:15
no register e164
gateway
timer receive-rtp 1200
telephony-service
load 7960-7940 P0030702T023
load 7912 CP7912080001SCCP051117A
max-ephones 24
max-dn 48
ip source-address 192.168.144.158 port 2000
service dnis overlay
url directories http://192.168.144.158/localdirectory
user-locale ES
network-locale ES
time-zone 28
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name name password pass
transfer-system full-consult
night-service code *1900
directory last-name-first
create cnf-files version-stamp 7960 Apr 12 2006 17:23:22
1 REPLY
Hall of Fame Super Gold
Re: Security concern in CME 4.0
1720 is h.323 and 2000 is SCCP. You may want to restrict the first to avoid casual calls if you are facing the internet. Port 2000 is much less an issue because to place calls the phone need to be registered that is fully configured in the system, or auto-reg, auto-assign enabled.
Hope this helps, Please rate all useful posts!
107
