security CUCM 7
uccxucce
Hello I need to know step to step how can I configured security in CUCM 7 so that two ip phone can encryptation yours calls.
anyone can help me?
Thanks.
Jaime Valencia
All necessary steps and items required are here:
Cisco Unified Communications Manager Security Guide, Release 7.0(1)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hello Java,  can you explain if is necessary to add a New Phone security Profile for each one model of ip phone?
if it is this way what type in device security mode I should choose, the option are Authentication or Excrypted, and if the authentication mode (By Null string) I should choose ? or LSC or MIC? I am confused.
Best Regards
