Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
security CUCM 7
Hello I need to know step to step how can I configured security in CUCM 7 so that two ip phone can encryptation yours calls.
anyone can help me?
Thanks.
Re: security CUCM 7
All necessary steps and items required are here:
Cisco Unified Communications Manager Security Guide, Release 7.0(1)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: security CUCM 7
Hello Java,  can you explain if is necessary to add a New Phone security Profile for each one model of ip phone?
if it is this way what type in device security mode I should choose, the option are Authentication or Excrypted, and if the authentication mode (By Null string) I should choose ? or LSC or MIC? I am confused.
Best Regards
249
